DIYnot
Local | Network
   DIYnot > Forums
Local | Network
oil central heating boiler not working
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
pleasehelpmetoday
from United Kingdom
PostPosted: Fri Jan 02, 2009 3:43 pm Reply with quote
Hi my boiler is locking out since running out of oil 2days ago -Ive had adelivery today.
Boiler is danesmann Hatchmoor 12/19
please can you help as its so freezing here
Back to top
 Alert Moderators
crockett
from United Kingdom
Thanked: 32 times
PostPosted: Fri Jan 02, 2009 3:49 pm Reply with quote
You need to bleed the oil supply line. This can be done at the pump on the burner. The pump is where the oil line connects to on the burner, if you look at the pump it will have a grub screw located on it, which you can undo slightly to let the air out, catching any oil with a cloth / paper towel. Then try to reignite.
Back to top
 Alert Moderators
leakydave
from United Kingdom
Thanked: 52 times
PostPosted: Fri Jan 02, 2009 3:50 pm Reply with quote
You will need to bleed oil through the oil line. An oil pump wont pump air. Can be messy... wear rubber gloves.
Isolate oil supply; loosen flexi oil line from burner; open supply and drain oil into suitable container; isolate supply again; reconnect oil line to burner; open oil supply. Reset boiler and cross your fingers. Check for any leaks from the oil line connection.
Uncontaminated oil can be returned to your oil tank... DON'T tip it down the drain. Dirty oil can be poured onto tissue or newspaper and burnt.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi back boiler no hot water but central heating working? 6 1120 Wed Dec 26, 2007 9:42 pm
Boiler working but no central heating- Help please! 2 420 Tue Apr 03, 2007 8:34 am
Boiler working but central heating will not come on 7 380 Thu Sep 20, 2012 5:27 pm
h/w & central heating stopped working - Wallstar boiler 15 100 Fri Sep 23, 2011 12:00 pm
Central heating not working but boiler is fine 4 120 Sun Sep 01, 2013 5:44 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
