During the recent sub zero conditions, my radiators has decided to give up on me, and I would like some advice on a long term fix..
A few weeks ago, one of my radiators decided not to work properly, where the top half is cooler then the bottom. I tried to bleed the radiator, but I bled it to the point where there were no more air coming out.
A few days later, all but one radiator on the second floor, decided not to work anymore. And again, I tried to bleed them all, but again, none of them had any air in them to come out.
I have been told that the pipes going to the feed and expansion tank is full of sludge. To fix, I need to have a garden hose, which at one end plug into the garden tap, the other into a strange looking tap (located inside my garage). I turn the garden tap on, which will fill the water into the expansion tank, then bleed all the radiators. This is what I did today, and it worked! But after 10 hours, the radiators are starting to cool down again, therefore I would need to redo this hose business in the morning.
The question is, if I continue to do this regularly, would the problem eventually go away?! or is this just a short term fix and I would need to get a plumber to come in to rework on the pipes?! I wouldnt want to blast water into the expansion tank everyday to keep it running properly!
Many thanks, I look forward to your reply
Neil
Neil
