You cannot use solar in conjunction with the combi function though
You could add a cylinder which can be heated by solar as well as by the boiler.
You cannot use solar in conjunction with the combi function though.
Solar only heats hot water!
Tony
Is it not possible to feed the combi boiler with preheated water from the cylinder?
solar forum
http://www.navitron.org.uk/forum/[/QUOTE]
Solar yes, + boilers? back of a postage stamp comes to mind.
Solar + combi is perfectly reasonable. You can if you wish just use the combi as a system boiler.
Solar is viable so long as you don't over spend on a system.
Thank you for your opinions, we did actually go for the combi option to save space.
I have often wondered what you are supposed to do when the radiator in a box on your roof freezes and splits.
Since its on the roof you will need scaffold to safely get up there.
unless they have a frost stat and auto drain feature?
