DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Halogen lights
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  Bookmark and Share View previous topic :: View next topic
Author Message
eamonnmartin
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 08, 2003 5:16 pm    Post Subject:
Halogen lights
Reply with quote Thanks
Can you use dimmer switches with Gu10 halogen lights? I have 2 fittings running off one switch which worked for a while but now it's only working very rarely and only at full brightness when it does. As you can probably tell I'm a complete novice with these things so any advice is gladly accepted.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Wed Jan 08, 2003 7:55 pm    Post Subject:
Re: Halogen lights
Not being familiar with the actual lamps you refer to
option 1)
If they are low voltage and running from a transformer.
Most normal dimmer switches can not run a conventional transformer with out going wrong (as yours appears to have) you need to have an eletronic transfomer which you can get from (also an electronic dimmer too)
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=10066&ts=55416
Option 2)
If they are mains fed lamps you may have over loaded your dimmer switch, in which case you will need to get a bigger one that can handle the total wattage of your lamps
If you are in America i would suggest you try a local electrical wholesaler
Back to top
 Alert Moderators
DNADECORATING
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 08, 2003 10:08 pm    Post Subject:
Re: Halogen lights
THE GU 10'S ARE 12VOLT LIGHTS YOU CAN USE THEM WITH A DIMMER (IN YOUR CASE I THINK THAT YOU NEED A NEW SWITCH-HOW LONG DID THE OLD ONE ACTUALLY WORK FOR?)
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Wed Jan 08, 2003 11:00 pm    Post Subject:
Re: Halogen lights
I am gratefull for the fact that you said the lamps are 12 volt, however just changing the switch (to an identical one) is only curing the problem not the cause. it is a popular misconception that a dimmer switch can run any light.
If you look at the link it does say it is "full dimmable"
there is also a dimmer switch made specifialy for "electronic transformers"
it is http://www.screwfix.com/app/sfd/cat/pro.jsp?id=18588&ts=66712
Back to top
 Alert Moderators
Lee1980sim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 28, 2006 11:42 am    Post Subject:
if you have 2 fittings running from 1 switch then you have probably overloaded the switch as most switches will only power one fitting you will more than likely need to replace the switch with a more powerful one or change your bulbs to ones that when all added up only come to the total wattage that the switch can handle (not an expect but daddy is lol icon_biggrin.gif )
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 28, 2006 3:56 pm    Post Subject:
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 159 times
PostPosted: Tue Mar 28, 2006 6:23 pm    Post Subject:
Wonders never cease to amaze . . . Lee has made 3 posts, one in reply to a thread MORE THAN THREE YEARS OLD! I mean, in what manner has he been exploring the forum????
I do hope eamonn martin solved his problem though.
Back to top
 Alert Moderators
Pens
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 28, 2006 9:38 pm    Post Subject:
Back to top
 Alert Moderators
sdminus
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 28, 2006 9:57 pm    Post Subject:
GU10's are NOT 12 VOLT.
neither are GZ10's
Gu and GZ 10 lamps have a max rating of 50 Watts each. they will not require high capacity switches. Ie if there is only 2 of the lamps a conventional 200 W or 5 A switch will be adequate
Scott
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
halogen lights mysteriously stopped working when timer fan a 6 420 Sat Apr 18, 2009 11:45 pm
Why do my new B&Q halogen lights smell of burning? 16 3320 Sat May 10, 2008 8:38 pm
50W Halogen low voltage ceiling lights & conventional di 3 560 Sun Jul 10, 2005 11:03 am
Mains Halogen lights 9 620 Sat Dec 02, 2006 8:42 pm
Installing New Halogen Lights On An Older Lighting Circuit 17 16080 Thu Sep 08, 2005 11:27 am
DIYnot
