help. Vibrating noise from roof guttering / felt
28 Jan 2009
Lincolnshire
I have a vibrating noise which comes from the felt which overlaps the
guttering on our roof ( sounds like a birds wings flapping ) Has anyone any ideas as to how to stop this. ie cutting the felt back or fastening the felt in some way.
It is definately from the felt rattling against the guttering as I have seen it.
Regards Kevin
Hi, Is your roof fairly new? if so it probably got breather felt hanging in to the gutter and this is what is vibrating, it should have a heavier felt going in to the gutter like 5u felt and then the beather felt on top but not as long, beather felt should not pass the fascia board for this reason.
Hope this helps
Dave
I see (though not hear) this alot where some plastic DPC felt has been inserted at the eaves and draped into the gutter - usually after a fascia replacement or where the existing felt has rotted at the eaves and some polypropylene felt slid in.
This stuff felt is too thin and reverberates in the wind.
There should be a proper plastic eaves tray fitted, or at least some thick EPDM sections which will be more UV stable than bituminous DPC felt
Thanks for the help, the gutters were replaced along with the facias and soffits a few years ago and thinking back the noise may have been there since then. I will ring the local company which installed them as I know they also removed the lower row of tiles and fitted some new felt
Thanks Kevin
I had this and thought is was pipes in the attic. Turned out that it is birds washing in the gutters and flapping about, it may be something else but this is what it was at my house, its has taken me ages to find out. :wink:
