DIYnot
Local | Network
   DIYnot > Forums
Local | Network
New Drill Bit Set - For Masonry, Timber, & Metal.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials
Author Message
EViS
from United Kingdom
PostPosted: Sat Jan 31, 2009 4:12 pm Reply with quote
I need to invest in a quality drill bit set. One set for Masonry, one for Timber, and one for Metal. The latter can be cheaper as it will be used least often.
I'll be using these primarily with my cordless 18V BHP452 Makita drill/driver using Lithiom-Ion batteries. They will be occasionally used with a wired Bosch.
What manufacturer do you recommend? I've had a look over at D&M Tools but the choice is so vast I have no idea what to go for.
I don't mind paying a bit more for quality that will last and rather a drill only set (as opposed to one that comes with pliers/spirit levels/etc.).
Back to top
 Alert Moderators
swbjackson
from United Kingdom
Thanked: 108 times
PostPosted: Sat Jan 31, 2009 6:50 pm Reply with quote
Back to top
 Alert Moderators
EViS
from United Kingdom
PostPosted: Sat Jan 31, 2009 7:37 pm Reply with quote
Thanks for the advice there. I've heard good things about the Bosch 'Blue' line. However, is 7 drill bits sufficient?
I see the wood & metal options are non-branded. This in itself is not necessarily a bad thing (produced in the same factory, etc.). But why do you recommend these as opposed to other sets?
Back to top
 Alert Moderators
neds
from United Kingdom
Thanked: 27 times
PostPosted: Sat Jan 31, 2009 8:06 pm Reply with quote
I have had good results with the Dewalt Extreme 2 masonry drill bits. However these days drilling with regular masonry drill bits is a bit of a chore with my regular 18v and I just end up using my cordless 12V SDS drill for masonry.
Back to top
 Alert Moderators
swbjackson
from United Kingdom
Thanked: 108 times
PostPosted: Sat Jan 31, 2009 11:22 pm Reply with quote
Unbranded tend to be a bit cheaper. There's a nice variety in the wood set and plenty of spares in the metal set.
Back to top
 Alert Moderators
EViS
from United Kingdom
PostPosted: Sat Jan 31, 2009 11:35 pm Reply with quote
The metal choice looks supiciously cheap from a price perspective. They're also not made from HSS.
I like the timber and masonry sets though. They're also both sold by screwfix.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sun Feb 01, 2009 12:07 am Reply with quote
yes, if you wanmt to drill 7 sizes of hole.
I hate "drill bit sets" you have already asked is 7 enough? so i can see you are not sure either.
please read the following then decide. (i make the bits / sizes / cost up)
You buy a "set" of drill bits. 3, 4 ,5, 6, 7 & 10 mm = £12
The 3 is too small, the 10 is too big, that leaves you 4 bits
averge cost is £2/bit you have just spent £4 on stuff you don't want.
You then use the 4mm bit, press to hard and .............
so you use the 5mm bit, you then realise you shouldn't have as the hole is 1mm too big.
My point is, why not buy a couple of bits in the sizes you do want, not the sizes you never use in a set
Back to top
 Alert Moderators
EViS
from United Kingdom
PostPosted: Sun Feb 01, 2009 12:22 am Reply with quote
Oh you are quite correct in what you state. But one does never know when they may need a certain size... Hence buying a set which covers all basis isn't exactly a bad idea, as long as that set includes the most commonly used sizes. It's this latter point which is extremely difficult to apply.
However, buying individually, where do you keep all the bits you buy? Mixed up together within a toolbox? It's nice to have some sort of 'case'.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sun Feb 01, 2009 12:58 am Reply with quote
if you have "some sort of case" where do you keep the ones that are the same size you already have?
but as i said you will be paying for bits you really dont want, but are conned into buying them, like you, "just in case"
did you also know that 2 million brits / year spend a fortune on 1/4 inch bits they dont want. They only want the hole.
Back to top
 Alert Moderators
EViS
from United Kingdom
PostPosted: Sun Feb 01, 2009 1:03 am Reply with quote
Well all the bits I already have are just rattling around in an old set case (i.e. in the compartment where the set hand screwdriver was icon_rolleyes.gif). I'm chucking the lot and starting fresh, going to look after these new bits better this time around, and sharpening them often.
Back to top
 Alert Moderators
swbjackson
from United Kingdom
Thanked: 108 times
PostPosted: Sun Feb 01, 2009 6:49 am Reply with quote
[quote="EViS";p="1125320"]
For metal drill bits I just use a set from B&Q. The ones I use most often are the small ones and I'm always snapping them so there's no point in spending out a lot.
Back to top
 Alert Moderators
EViS
from United Kingdom
PostPosted: Sun Feb 01, 2009 10:56 am Reply with quote
fair point there swbjackson icon_smile.gif.
Back to top
 Alert Moderators
JonB
from United Kingdom
Thanked: 24 times
PostPosted: Sun Feb 01, 2009 11:03 am Reply with quote
All my working life as a Maintenance Fitter (retired now) we only used Dormer HSS drills for metal.
JonB
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 24 times
PostPosted: Sun Feb 01, 2009 11:04 am Reply with quote
I agree (we know you shouldn't but you do) which is why i said
breezer wrote:
......You then use the 4mm bit, press to hard and .............
which brings me back to the point of why buy a whole set?
Back to top
 Alert Moderators
gregers
from United Kingdom
Thanked: 276 times
PostPosted: Sun Feb 01, 2009 11:40 am Reply with quote
i use these a lot,totally impressed with them.
http://www.screwfix.com/prods/95497/Drill-Bits/Drill-Bit-Sets/HSS-Sets/Erbauer-HSS-Cobalt-Drill-Bit-Set-15-Pc#
and i use my sds bits for anything masonary.i personally wouldnt bother using the normal masonary bits,i have burned to many out in the past.
mind you these seem very good value,
http://www.screwfix.com/prods/40735/Drill-Bits/Drill-Bit-Sets/Combination-Sets/Erbauer-182-Piece-Assorted-Drill-Bit-Set?cm_re=SEARCHPROMO-_-ERBAUER%20DRILL%20BITS-_-40735
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
How to secure timber to external wall? 4 200 Sun Mar 04, 2012 8:22 pm
timber framing nails 7 740 Fri Jan 09, 2009 6:56 pm
reclaimed and scrap timber 11 1360 Wed Jul 27, 2005 8:05 pm
Where can I buy 12mm square lengths of timber? 7 220 Wed May 16, 2012 6:22 am
Cheapest place for timber in surrey? 4 160 Tue Oct 30, 2012 8:14 pm
DIYnot
