DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Cracks on bay window wall after double glazing installed
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
bloomfieldtj
from United Kingdom
PostPosted: Fri Feb 13, 2009 9:26 pm Reply with quote
We live in a semi-detached house with bay fronted windows upstairs & down (5 window bays). We recently had the old wooden windows replaced with new UPVC ones. The work was done by a reputable company and the bays were fully supported with steel rods during the work. However, I now notice a small hairline crack on either side of the upstairs bay window. running from below the window sill on either first window bay, to the skirting board below. There are no cracks on the downstairs bay, nor anywhere else in the house.
Is this normal after replacement windows? The cracks look quite small and I can't see any cracks on the outside wall.
Any advice would be welcome.
Many thanks.
Back to top
 Alert Moderators
alastairreid
from United Kingdom
Thanked: 476 times
PostPosted: Fri Feb 13, 2009 10:21 pm Reply with quote
i wouldnt worry about it, hairline cracks in plasterwork arent unusual after bay window replacements.
give the new bays some time to settle then widen the cracks a little and fill with decorators caulk, let it set and then give it a light sanding before painting.
Back to top
 Alert Moderators
stuart45
from United Kingdom
Thanked: 130 times
PostPosted: Fri Feb 13, 2009 10:53 pm Reply with quote
There used to be problems with cracking to the upper bay(if built in masonry) when timber bay windows were replaced with plastic to the extent that sometimes the windows would have to be removed and bay poles and steel plates put in.
The better quality modern ones are said to have enough reinforcement to prevent this. As Alastair says some hairline cracks are quite normal.
I know one surveyor who isn't too keen on the idea of replacing timber bays with plastic when the upper bay is built in masonry.
Back to top
 Alert Moderators
DavidPeckham
from United Kingdom
PostPosted: Tue Feb 28, 2012 1:03 pm Reply with quote
Sorry to bump an old thread but as opposed to just caulking I understand you can chisel the crack out and fit a steel strap across before plastering over. Does anybody know the correct name of these bay window crack-straps (for want of a better phrase!) and where I can get some from. Googled multiple variations and can't find an actual name of them in order to purchase.
Regards
Kevin
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Cracks Around Door Frame new and increasing - subsidence? 8 160 Thu Dec 27, 2012 1:12 pm
Large cracks around windows- What do you reckon ? ? 9 1040 Wed Nov 25, 2009 7:01 pm
Cracks around UPVC doorframe 2 100 Tue Jun 26, 2012 7:16 pm
Installed my low-e backwards 2 260 Wed Jul 14, 2010 1:08 pm
How to tell if I got fire proof doors already installed? 6 1020 Tue Aug 11, 2009 12:15 pm
DIYnot
