When turned on, the main burner ignites for around 15 seconds, then goes out. It will not re-ignite unless the boiler is switched off then turned on again. Then the burner wil light for around 15 seconds again and then go out. After around 15 minutes trying to get it to light and repeating this cycle, the radiators begin to heat up. Can anyone one help with a cure?
