Main Medway Super problem
1 Mar 2009
Gloucestershire
I had a problem with the pilot staying lit, cured it by cleaning the jet. But now the boiler doesn't fire-up when I turn the hot taps on. I havn't touched anything other than the pilot jet. Any tips would be appreciated.
Have you cleaned it or blocked it? you shouldn`t be cleaning anything related to the gas side of the appliance, get a Gas Safe Registered fitter to sort it.
I removed and cleaned the jet, the small section with the gauze and olive.
I am an engineer, though not registered CORGI. Just trying to find out if it was something I could put right myself.
Are you a gas fitter?
Many thanks namsag.
By the way, I work on electrical, electronic, pneumatic, hydraulic and steam systems. I am required, by law, to work in a safe manner, whether that be in my own property or at work. Gas fitting is in itself is a skill/trade and like electrical work not a 'black art' or some kind of special magic. try not to be so patronising to posters. Not everyone is a numpty!
Eh did you miss the bit where he said had cured pilot out by cleaning it
He had a problem with the pilot staying lit, probably thermocouple, he has now cleaned the the jet, he know can`t fire up the heater, I assume he is not a fitter and unused to servicing water heaters he has probably blocked the pilot injector, he now has two problems instead of his first problem. What do you think Sherlock?
He had a problem with the pilot staying lit, probably thermocouple, he has now cleaned the the jet, he know can`t fire up the heater, I assume he is not a fitter and unused to servicing water heaters he has probably blocked the pilot injector, he know has two problems instead of his first problem. What do you think Sherlock?
good spilling
