climber101
Joined: 05 Jan 2009 Posts: 61 Location: Coventry, United Kingdom Thanked: 0 times
Posted: Tue Mar 03, 2009 10:53 pm Post Subject: uPVC window size help |
I’m looking for a uPVC window approx 1500mm high and I’m thinking the width is somewhere between 565 and 600mm, although I could probably go a bit wider.
My initial look on the ‘net has found some widths at 610mm but not that height
Two questions please
a) any suggested window ‘standard sizes’ please within the 1500mm high and 565 to 600mm wide ballpark I describe or whether I would be having to go a bit wider
b) to suit your suggested size what size of cutout into blockwork to allow any recommended fitting gaps plus fitting a c.100mm cill at base of window
Thanks in advance for any comments |
wms
Joined: 09 Dec 2007 Posts: 528 Location: Nottinghamshire, United Kingdom Thanked: 0 times
Posted: Tue Mar 03, 2009 11:21 pm Post Subject: |
Why are you worried about standard sizes 99.9% of pvcu windows are taylor made to suit the opening you have. forget the diy sheds internet and all that carp go to a local fabricator who will make one to the size you require without the need to mess about changing opening sizes. __________________ Its All about the right tools in the right hands! |
^woody^
Joined: 03 Sep 2006 Posts: 5717 Location: Birmingham, United Kingdom Thanked: 52 times
Posted: Tue Mar 03, 2009 11:36 pm Post Subject: |
Have the window made to what size you want.
Remember to design to whole or half brick/block dimensions so that the piers each side work nicely without lots of cutting.
Allow 10mm (5mm each side) of the frame for the actual opening dimension |
climber101
