It would be helpful for something I am doing on the central heating system, if I could use a 15mm silver braided connector - a similar sort of thing as is used for tap connections, but 15mm at each end.
What concerns me is that the ones I have seen are rated up to 70 degrees centigrade, but looking at my Bosch boiler instructions, it technically reaches 80 degrees centigrade. At a guess the water wouldn't be at 80 degrees by the time it reaches the point in the system where I'd like to put the connector, but I wondered if anyone could advise if its a problem using such a connector in the central heating system.
Any thoughts greatly appreciated.
