DIYnot
Local | Network
   DIYnot > Forums
Local | Network
BOSCH MAXX drum not spinning
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
chelsea1
from United Kingdom
PostPosted: Thu Mar 12, 2009 7:35 pm Reply with quote
My Bosch Maxx will not spin, the belt is on and looks ok. I can hear the front panel clicking as though it is trying to send the message to somewhere in the machine for the drum to spin. It fills with water and drains ok.
Does anyone have any ideas on why it won't spin ?
Thanks for any info given.
Rich
Back to top
 Alert Moderators
cakeman
from United Kingdom
Thanked: 51 times
PostPosted: Fri Mar 13, 2009 12:28 am Reply with quote
check the carbon brushes in the motor if less than 10mm then change
you could take of the belt and put it on spin , if the motor rotates the it could be the capacitor or the motor simply too low on strength
need to narrow it down by checking each part
Back to top
 Alert Moderators
chelsea1
from United Kingdom
PostPosted: Fri Mar 13, 2009 8:17 am Reply with quote
Thanks for the info will try this.
Rich
Back to top
 Alert Moderators
Leccy758
from United Kingdom
Thanked: 196 times
PostPosted: Sun Mar 15, 2009 1:47 am Reply with quote
Motor Capacitor on a 'Brushed Motor on a Bosch Washer'
Cant recall seeing one
The symptoms are quite indicative of worn brushes though (although occasionally with bosch motors the brush holders accumulate carbon dust preventing the carbon brush from moving freely in the holder)
Generally with worn brushes it stops spinning corectly, then does not spin eventually does not agitate during wash either
If it gets bad it can damage the motor
Back to top
 Alert Moderators
libby lou lou
from United Kingdom
Thanked: 43 times
PostPosted: Sun Mar 15, 2009 2:08 am Reply with quote
Need to test brushes? stretch em, put them back, lf lt works, you got another week or two.
Back to top
 Alert Moderators
chelsea1
from United Kingdom
PostPosted: Sun Mar 15, 2009 2:46 pm Reply with quote
Thanks for the replies, however I have seen where the motor is, it's located at the bottom of the washing machine. How do you go about adjusting /changing the brushes or more to the point the motor. I have tilted the machine forward but it really does look difficult to undo the two bolts which appear to hold the motor in place, especially with the tension on the belt, which would obviously have to come off first ? or is it quite easy ?
Regards
Rich
Back to top
 Alert Moderators
rocks1
from Unknown or unspecified country
Thanked: 1005 times
PostPosted: Sun Mar 15, 2009 2:54 pm Reply with quote
Posted: Mon Feb 02, 2009 10:59 am Post Subject: If it wont spin, change your brushes
Just had the same problem. Easy to fix. Take the back off the machine and undo the 2 bolts that hold the motor in place. Slide the motor off the fittings and remove the electrical terminal and the earth wire ( these both just pull out). You can now take the motor out and get to the brushes. There is one either side of the motor. Pull the wire off each brush and remove the spring. The brush will come out with the spring. Getting the new ones in can be a bit fiddly, but the 12 I paid for the brushes is better than 170 for a new motor.
Back to top
The following user says thank you to rocks1 for this useful post:
ezd333 (23 Jul 2013)
 Alert Moderators
chelsea1
from United Kingdom
PostPosted: Sat Mar 21, 2009 3:59 pm Reply with quote
Thanks for all the help, I replaced the brushes, they were worn down to a little stump, fitted the new ones at a cost of 5.89 for a pack of two and 3.95 postage from eSpares and as I type this reply my machine is happily spinning again. This almost cost me 400 + for a new machine my wife was about to buy. Phew. Thanks for your reply rocks1, I followed your instructions.
Regards
Rich
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch Maxx WFL245S wash machine not draining or spinning 9 6420 Sat Apr 10, 2010 10:34 am
Bosch Maxx 100, not filling or spinning. 2 80 Sat Feb 04, 2012 8:25 pm
BOSCH MAXX Tapping noise when spinning 7 260 Thu May 26, 2011 2:16 pm
Boschi Maxx not spinning 3 340 Mon Jul 05, 2010 5:21 pm
Bosch MAXX 1200 WFL 2400 not doing anything! 3 1140 Sun Jan 31, 2010 12:12 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
