DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Tarmac on top of concrete???
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
plumbermitch
from United Kingdom
PostPosted: Thu Mar 26, 2009 10:44 am Reply with quote
Can you or can you not lay tarmac on top of concrete?
Thanks for any help you can give.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1299 times
PostPosted: Thu Mar 26, 2009 11:09 am Reply with quote
Do you mean like ..... on bridges?
Back to top
 Alert Moderators
plumbermitch
from United Kingdom
PostPosted: Thu Mar 26, 2009 11:48 am Reply with quote
No not on bridges!--just looking for a cheap and easy way to cover over old cracked concrete in my front garden--there is also a large area of existing tarmac and an unwanted flowerbed so I hoped to be able to use tarmac so that it would match up. One contractor quoted for full excavation and installation of new base and two layers of tarmac--all got a bit too expensive (100 sq.metres) but another said he could lay a topcoat of 6mm tarmac over the existing concrete--a lot cheaper-but how long would it last???
Back to top
 Alert Moderators
PrinceCharles
from United Kingdom
PostPosted: Thu Mar 26, 2009 1:13 pm Reply with quote
Yes you can. Plenty of concrete roads have been overlaid with black. The success of your garden venture however would depend on the condition and stability of the underlying concrete.
HRH
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1299 times
PostPosted: Thu Mar 26, 2009 2:00 pm Reply with quote
[for example]
Tarmac roads are laid across concrete bridges
Back to top
 Alert Moderators
mattylad
from United Kingdom
Thanked: 151 times
PostPosted: Thu Mar 26, 2009 4:23 pm Reply with quote
You should have seen Rogue Traders last week.
They had a cowboy laying 6mm ish tarmac over concrete.
Lifted up easily.
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1299 times
PostPosted: Thu Mar 26, 2009 5:01 pm Reply with quote
What? Do you mean he did not use Uni-bond
Back to top
 Alert Moderators
plumbermitch
from United Kingdom
PostPosted: Thu Mar 26, 2009 5:14 pm Reply with quote
I know so little about it that I don't know if woody's Unibond is a joke or not!!--but the man did say that a tack coat would be applied to the concrete first. What depth of 6mm would be deep enough?
Can I watch Rogue traders on i-player?? What channel was it on and on what night.
Back to top
 Alert Moderators
PrinceCharles
from United Kingdom
PostPosted: Thu Mar 26, 2009 5:38 pm Reply with quote
You would definitely need to tack coat the area before laying any black. The key to a good finish though is the condition of the concrete underneath. If you lay your black on an unstable surface this will reflect up to your finished surface. 6mm does sound a touch thin, I would aim for 10mm thick using 6mm bitmac.
As a rule of thumb the layer thickness should be approx 1.5 times the size of aggregate.
HRH
Back to top
 Alert Moderators
priorsleevalley35
from United Kingdom
PostPosted: Wed May 13, 2009 4:33 pm Reply with quote
No problem with overlaying concrete with tarmac provided a few guidelines are followed.
Surface needs to be sound, any cracked areas treated. A good quality bond coat applied and then specialist anti cracking material - supplied by me of course - laid over any joints to prevent reflective cracking.
At least 25mm of 6mm Dense Surface Course laid by a quality contractor.
Contact me for further information.
Regards.
Priorsleevalley35
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Tarmac to concrete edge 4 80 Mon Feb 27, 2012 5:43 pm
tarmac 2 80 Mon Apr 23, 2012 1:44 pm
Tarmac repair 3 60 Fri Sep 14, 2012 9:40 am
Diesel on new tarmac driveway 11 5020 Sun Oct 28, 2012 3:28 pm
Tarmac Drive and Inspection Chamber 3 80 Mon Apr 02, 2012 3:11 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
