Bath tap hole spacing
27 Mar 2009
I have a shiny new double ended bath to fit and it comes without tap holes.
The Bath tap/mixer I have bought to fit to the bath has 3 separate posts (hot/cold/ spout) which are connected under the bath by flexi hoses.
So within reason, they could be any distance apart. But what distance "looks" right ?
Obviously, I'd like to know before drilling ;) So what do you guys in the know suggest.
Depending on the look you are going for, old bath tapes were made with 7" centres. If you have individual taps, maybe, one day you might change the taps ;) So, cutting the taps with 7" centres might be a good suggested position. If you aren't changing the setup in the future, cut the spacing that is cosmetically pleasing within the size of the bath. Don't forget to put tape on bath where you are cutting fella....
do you mean 3 seperate taps or do you mean it comes in 3 parts?
if the later then you need to assemble it and get a straight edge
when the inlet tails are level measure between the centres
The mixer has 3 separate components above the bath rim, not connected (so, 3 holes to drill).
Not looking to replace in the near future and would be restricted to a similar arrangement (3 parts).
I agree with the post "spacing that is cosmetically pleasing", but wondered what you guys have done previously.
