DIYnot
Local | Network
   DIYnot > Forums
Local | Network
what are 1 and 2 way pull switches?
Author Message
tapir
from United Kingdom
Thanked: 13 times
PostPosted: Sat Mar 28, 2009 12:57 pm Reply with quote
Replacing a pull switch for shower/extractor in my bathroom. I've killed the power, taken it down, made the diagram, identified from my main fusebox that I need 6A replacement....now I need to know the difference between 1 way and 2 way, so that I can buy the correct pull switch.
Am I right in assuming that:
1 way - wires from ceiling terminate in the pull switch - they don't go back into the ceiling and onto other switches
2 way - wires come in from ceiling, into pull switch COM and L1, and then back out to other switches.
My pull switch has:
Yellow/Green cable earthed to a connector on the back of the plate
Brown cable connected to COM
Blue cable (in brown sheathing) connected to L1
The cables all terminate in this switch, they do not go anywhere else.
Hope that someone can advise!
Thanks in advance
Tapir
edit: the pull switch controls the extractor fan, not sure what else i need to consider for this
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Sat Mar 28, 2009 1:03 pm Reply with quote
makes no difference which you have. (for your aplication)
1 way is just that , 2 way can be used as one way or two way. more info is in the "sticky"
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sat Mar 28, 2009 2:50 pm Reply with quote
2 way switching may also terminate at the switch depending on which wiring method and which end the switch is..
check the WIKI for common wiring methods..
Back to top
 Alert Moderators
TonyW2
from United Kingdom
Thanked: 62 times
PostPosted: Sat Mar 28, 2009 2:53 pm Reply with quote
Tapir--your "understanding" is not correct.
One way is a simple on/off switch whilst a two way switch can be interconnected with another on a light controlled from 2 different switches, (eg bedroom wall and overbed pull cord)
A two way switch can be used in a place that a one way would suffice, but not vice versa, so as Breezer says, for your case it is not critical. The price differences are negligible.
Back to top
 Alert Moderators
tapir
from United Kingdom
Thanked: 13 times
PostPosted: Sat Mar 28, 2009 5:20 pm Reply with quote
Thanks for the advice Breezer, ColJack and TonyW2 - one new light switch fixed in place and working, no burnt fingers or house with no power icon_smile.gif
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Sat Mar 28, 2009 11:18 pm Reply with quote
Back to top
 Alert Moderators
tapir
from United Kingdom
Thanked: 13 times
PostPosted: Sun Mar 29, 2009 3:49 pm Reply with quote
Steve wrote:
From here:http://www.urbandictionary.com/define.php?term=facepalm
Quote:
usually an image posted on a message board or online blog that expresses disgust over one person's idiocy.
FACEPALM. because expressing how dumb that was in words just doesn't work.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1952 times
PostPosted: Sun Mar 29, 2009 9:44 pm Reply with quote
I'd agree it's not full, but it's not completely wrong - with 2 way switching conductors do run from one switch to another...
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Pull cord switches: unreliable? 6 380 Wed Jul 09, 2008 6:50 pm
Do Trigger/Non-latching pull-cord ceiling switches exist? 3 1460 Mon Feb 14, 2005 2:26 pm
Dimmable Pull switches / problem. 16 620 Mon May 25, 2009 7:42 pm
Silent pull cord light switches? 11 1540 Fri May 09, 2008 11:22 am
Loading of Dimmable Pull Switches in Bathrooms 3 320 Sun Apr 27, 2008 9:07 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
