Aorman
Joined: 03 Apr 2009 Posts: 6 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Mon Apr 13, 2009 9:13 pm Post Subject: Old floorboards have a rise near one wall |
I have just ripped up my old carpet in readiness for a wooden floor, to see that on one sde of the room, next to the hearth, the flloorboards have a rise in them of about 20mm over 36 inches. In other words it is like a shallow bump about 6 inches from front to back, and about 36 inches from side to side. If you tip a saucer upside down, you'll get the idea.
Anyway, I am going to lay 6mm plywood on top of the floorboards, and now would like to know if I need to do anything else regarding the lump/rise.
Thanks |
xerxes
Joined: 13 Jan 2006 Posts: 970 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Wed Apr 15, 2009 10:16 pm Post Subject: |
I suggest you investigate further: remove the affected board(s) and check to find out how to remedy the problem.
It could be that you have a board which wasn't fixed down properly, and it has cupped; in that case replacing it with a flat board will solve the problem. |
