Hotpoint sdw60 slim line dishwasher
17 Apr 2009
Yorkshire
Can anyone help, I have the above item which is just out of warranty, when you switch it on the salt refill light flashes all the time and the machine starts on it's own!! The eco 45 light flashes on and off and the machine does not fill even though it sounds like it is. Cheers
water in base of mc ,tip mc back with towels on the floor when its stopped pouring water out check the spray arm are not loose its a nut at the bottom of the arm ,then check salt nut is tight ,then check the small turret at the back near the bottom spray arm all this is inside of mc .try it after this if it dont work you have a leak from under the mc . 6 screws to remove base and have a look.
