We are in the process of getting estimates for a new replacement gas boiler, amongst other bits. The gas meter is around 8meters from the present boiler and has a 15mm gas feed copper pipe. Gas hob is tee'd off from it in the kitchen.
One group of Gassaferegister fitters tell me that the present pipe is too small for the required pressure in a new boiler and 22mm (?) pipe will be required. The second group of Gassaferegistered fitters look at exactly the same pipe and tell me that it is OK and does NOT need replacing. Boiler will be in the same place.
So, here I am, hapless customer, footing the bill and the trained "experts" are telling me two totally different things.
Who is correct ? Are they both correct ? Can someone try to un-confuse me please.
Thank you
Brian
Thank you
Brian
