DIYnot
Local | Network
   DIYnot > Forums
Local | Network
leak in garage roof - what to do about it?
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Author Message
Klinsmann
from United Kingdom
PostPosted: Thu Apr 30, 2009 8:48 pm Reply with quote
I have a leak in my garage roof, the water is coming through and slowly rotting one of the main beams. I can't afford a professional fix and I'm utterly useless at DIY, so advice appreciated.
I think the water is getting in via a hole where a pin/big screw goes through to hold that part of the roof on. What I'm thinking as a first attempt is to get on a stepladder, then putting some of that expanding gunge stuff through/around the hole and hope that stops water coming in. Then get the bad wood off the beam and treat the remainder with something suitable which stops/prevents rot.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1594 times
PostPosted: Thu Apr 30, 2009 9:19 pm Reply with quote
Parts of your post are not very clear, is the roof finish felt or somthing else? Any chance of a photy?
Back to top
 Alert Moderators
Klinsmann
from United Kingdom
PostPosted: Thu Apr 30, 2009 10:08 pm Reply with quote
Photo - yes - but how do I add it?
Roof is I think something like corrugated sheets of fibeglass or another pressed material. I can't help but be vague, so if I can get a photo on I suspect that will say more than my words.
Back to top
 Alert Moderators
freddymercurystwin
from United Kingdom
Thanked: 1594 times
PostPosted: Thu Apr 30, 2009 10:37 pm Reply with quote
Back to top
 Alert Moderators
Klinsmann
from United Kingdom
PostPosted: Tue Jul 14, 2009 11:00 am Reply with quote
The original post - now with photo's:
Pictures in my album and (if this works) below.
http://www.diynot.com/network/Klinsmann/albums/3315
Back to top
 Alert Moderators
alastairreid
from United Kingdom
Thanked: 710 times
PostPosted: Tue Jul 14, 2009 11:25 am Reply with quote
acrypol applied around the bolt holes from the outside.
Back to top
 Alert Moderators
Klinsmann
from United Kingdom
PostPosted: Tue Jul 14, 2009 3:54 pm Reply with quote
Thanks for that advice, I'll give it a go. Hopefully I won't fall through the garage roof in the process - not that you'd be liable if I do. icon_lol.gif
Back to top
 Alert Moderators
Klinsmann
from United Kingdom
PostPosted: Sun Jul 19, 2009 10:03 pm Reply with quote
Had a look round for Acropyl or similar to no avail, but found Thompson's roof and gutter sealant so I'll be on the roof putting that round the bolts and crossing my fingers.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
Asbestos Corrugated garage roof leak 9 13440 Wed Jan 17, 2007 12:08 pm
Leak where garage roof joins flat roof 13 900 Sun Feb 21, 2010 4:41 pm
New garage roof leak 2 80 Fri Jan 06, 2012 10:12 am
Major leak in flat garage roof needs a quick fix. 12 1120 Fri Jan 20, 2012 10:58 pm
flat roof leak replace/over cover with epdm 6 220 Tue May 01, 2012 7:00 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
