andy3050
Joined: 08 Dec 2004 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Wed Dec 08, 2004 1:30 pm Post Subject: advantages and disadvantages |
what are the advantages and disadvantages of ring and radial circuits??? |
comms
Joined: 13 Nov 2004 Posts: 828 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Wed Dec 08, 2004 4:13 pm Post Subject: |
Radial circuit; 4mm cable & a protective device of 30/32amp will serve a max floor area of 75m sq
Radial circuit; 2.5mm cable & a protective device of 20amp will serve a floor area of 50m sq
Ring main; 2.5mm cable & a protective device 0f 30/32amp will serve a floor area of 100m sq.
All the above can have unlimited outlets & fused spurs, you can have as many unfused spurs as there are outlets.
So basically it's down to area coverage & cost of 2.5mm cable against 4mm cable. |
plugwash
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Wed Dec 08, 2004 5:08 pm Post Subject: |
the word spur has no real meaning in terms of a radial
its perfectly acceptable to take a branch off a radial to as many sockets as you like |
pna
Joined: 26 Aug 2004 Posts: 156 Location: Cambridgeshire, United Kingdom Thanked: 0 times
Posted: Thu Dec 09, 2004 11:54 am Post Subject: |
Radials are easier to wire (ignoring 4mm over 2.5mm) as no need to get the cable back through to the CU to make a ring; the run length of cable for a radial circuits is also limited to circa 30m. |
