I have recently moved into an old property and have an old boiler approx 1975. This seems to be working okay, however I want to change the Boiler Time Clock controller as this looks a bit Dinosaur!! and install a new digital room thermostat.
From the back of the boiler there appears to be 2-leads, one I am guessing is the 240v mains connections as this has cable has L,N & Earth wire, and the other I am not sure (this only has Live/Neutral connection) is this for the pump or motor???
My question is will I be able to replace the Boiler Time Control Clock with a newer style 7-day digital device install this onto the boiler and then wire a new digital room thermostat from this controller?
Not sure what type of boiler, its a floor standing Boiler which does my CH & HW thats about all I know. The hot water cylinder is up stairs in the loft.
Any advice would be greatly appreciated
