Meter tails sizes
9 Dec 2004
Does anyone know what the present regs state should be the size of meter tails for a normal size home with a split load CU containing a 100A isolator and 63A RCD?
Cheers.
depends on how far away your CU is from the meter. generally, 25mm^2 are used
Plus a 16.0.sq.mm. Main Earth Conductor, often straight into the main service fuse block, if it's a PME system - most newer installs are PME.
