Regs re waste pipes
7 Jun 2009
Bournemouth
Hello
I rent a council flat and have had the go ahead from the council to swap around the bath and basin to fit a shower.
They mentioned building regs in terms of altering the waste pipes which I will have to do. Culd someone let me know what I should look out for.
You don't have to look out for anything. B/regs will not apply
Installing/moving a bit of 40mm pipe and a trap does not require a b/regs application.
I would agree if that were the case but the OP is also proposing to install a new shower & move the bath & that’s notifyable work;
• basin traps & waste runs are normally 32mm, bath is usually 40mm so the 32mm waste will have to be increased to 40mm;
• new waste connection (ideally directly into the soil stack), size & any venting requirements will be dependant on length of branch & water volume;
• existing branch lengths could also be affected depending on where the OP is moving them to, without knowing the layout, it’s impossible to say;
In fact the council has incorrectly advised the OP & it involves more than just the waste runs;
• remodeling the bathroom will require fitting of forced ventilation if none currently exists;
• existing electrical fittings & lighting may no longer be suitable depending on their age & if any of the electrical safety zones change as a result of installing the new shower & moving the bath
I've lifted this extract directly from the CNC website
http://www.cncbuildingcontrol.gov.uk/frequently_asked_questions.htm
under the heading;
“When do I need BR’s approval;
(ix) to install fittings and appliances within my house that involve
(a) The installation or alteration of the position of a WC, bath, etc?
(b) The installation or alteration of a heating appliance?
Well you better tell all the kitchen and bathroom installers, and all the plumbers who go out and move a WC pan. And all the other companies (including the OP's own Council) too who do this type of work
I don't see many applications from these guys, not do I seem any BCO's chasing this work up
My view, well renewing (even if refitted to a different place) is maintenance, even installing wastes for new shower to an existing bathroom where there was none previously, is not controlled work. The electrical connection may be, but the retrospective fitting of fans or altering electrics to such a bathroom is not either.
It seems altering a waste trap to a different type would be notifiable too
From your quote from cnc building control, a new or replacement fire or radiator, or fan heater on the wall requires a b/regs application too :rolleyes:
I'm sure they are raking the fees in
Like everything else, CNC is now moving towards being run as a self financing business & if & when it gets totally outsourced, it’s gonna get even worse. Unfortunately, personal interpretation of BR’s & weather you agree with them or not is irrelevant. I’m not saying I agree with the over regulated systems that have been introduced & forced on us since around 2000, I’m just pointing out the facts as they are. The odd problem & incorrect installation of waste pipes, windows etc. is trivial but if you know what’s required, it’s just as easy to do it correctly as not to. But in the case of moving a bath or installing a new shower, the implications for existing electrical services & safety zones could be dangerous or, indeed, fatal in certain circumstances. I can tell you from personal experience that changing or adding to an existing electrical circuit can necessitate fitting a new & compliant consumer unit & possibly a partial re-wire in the case of an ageing lighting circuit that has no earth.
I just try to give sound advice to ensure folks are aware of the rules (in some cases the law) & the implications of ignorance or ignoring them may have, particularly if they own the property. Once they know the score, it’s up to the individual if they chose to abide by the advice or not; I certainly won’t lose any sleep if they chose to ignore it. ;)
Hi Rich, I agree there does seem to be some ambiguity regarding the rules on this. However, I don't believe alterations to an existing bathroom is notifiable work.
A new bathroom in a room not previously used as such and work to external services - stack/drainage etc would obviously be classed as notifiable.
I thought I had some documentation somewhere regarding this "stance"/my interpretation but I can't find it. IIRC it had something to do with "material alteration" or "material change of use" but I can't remember :cry:
I was a bit facetious in that reply :rolleyes:
Anyway, this type of work only becomes notifiable if the work involves alterations to the actual drain and/or the soil stack. Some say this includes new connections (eg a boss) to the stack, but I don't know if it goes that far - it may be just alterations to the stack in terms of moving or reducing it.
My local council website & the CNC website are quiet specific, as per the extract I posted; it doesn’t appear at all ambiguous to me!
No question about that one.
As I said, I don’t think anyone is going to be overly worried about DIY’ers of even some that call themselves tradesmen making a bit of a lash up of the drainage (within reason) but I’m guessing the main reason for requiring notification is that installing a new shower or moving a bath could well breach existing electrical safety zones within the room & if the electrical installation is not up to scratch (RCD protection), it could be the cause of a fatal accident; I’d be interested to hear from the odd "sparky" who may be watching on this one.
Thanks for all the replys guys. I have added a few notes below.
I am an electrician so will be sorting all the electrics as required and sending off all the part P stuff etc. Light fitting being changed, 100m extract fan is already in place.
Both existing bath and basin have a separate waste into the main stack 40mm and 32mm respectively.
I think my only problem may be the length of the basin waste.
Max run for 32mm pipe is 1.7m, IIRC there's no specific guidance on losses for bends but just try to keep them to a minimum and upgrade the pipe if there's any doubt.
Have a look at Hep V O waste valves ( instead of traps) One of the best inventions of late. Also use swept bends on wastes, Not those awful 90 deg. knuckle bends :evil:
