Hi there,
Its summer so i haven't needed to run the CH for 4 months or so. I decided to let the CH run for a bit so i called for CH, and there seems to be no hot water being pushed out to the rads. The Boiler seems to be creating the HW but it seems like its not getting to the rads.
I read the literature for the boiler, and it said that over prolonged periods of no CH use [eg SUMMER!], the boiler runs the pump for a short period so it shouldn't seize [hmm]
Things i've checked:
- Reset boiler
- Some of rads valves have been left permanently open so shouldn't have stuck [right?]
- checked and re-commissioned the wireless thermostat and receiver
- turned up heat on boiler to full
- bled some of the rads i wanted the heat to go to.
The boiler seems to be operating fine itself, pressure seems to in the correct green zone, no faults are being indicated.
HW has been running fine over summer too.
IS there anything else i can do or try - and any indication of problem?
Cheers
simpson
- Reset boiler
Cheers
simpson
