Aquasplash101
Joined: 19 Jul 2009 Posts: 1 Location: London, United Kingdom
Posted: Sun Jul 19, 2009 5:34 pm |
I live in a ground floor maisonette.
I am thinking of splitting my large lounge into 2 bedrooms.
If I split it width ways ( which is the preferred choice ) only one of the bedrooms will have a window. I read on another site all bedrooms need a window but in the building regulations 2.3 it states all habitable rooms on the ground storey should either open directly onto a hall leading to a suitable exit or to be provided with a window.
Which is correct?
Can anyone point me in the direction of a definitive answer ?
Thanks in advance !!!  |
onebobo
Joined: 17 Aug 2008 Posts: 13 Location: Gwynedd, United Kingdom
Posted: Sun Jul 19, 2009 5:57 pm |
My estate agent told me recently that Bedrooms must have a window to be called a Bedroom. |
^woody^
Joined: 03 Sep 2006 Posts: 12210 Location: Birmingham, United Kingdom Thanked: 1118 times
Posted: Sun Jul 19, 2009 7:22 pm |
| onebobo wrote: | | My estate agent told me recently that Bedrooms must have a window to be called a Bedroom. |
LOL .... is that the same requirement that a person must be clueless t**t to be an estate agent?
Anyway, I've plagiarised this from a BC guidance note ...
"Means of escape requirements from a dwelling.
All habitable rooms to dwellings and extensions shall have first floor windows suitable for means of escape. This also applies to all ground storey habitable rooms, which do not connect to a hallway leading directly to an outside door."
Technically its not correct as there may be other ways to achieve fire safety, or the window could in fact be a door, but a window is the simplist |
CortinaV8
Joined: 30 Sep 2008 Posts: 495 Location: Cleveland, United Kingdom Thanked: 8 times
Posted: Mon Jul 20, 2009 10:32 am |
Dont know about the current regulations.
By my gran lives in a fairly large house partially built into the side of a hill, a number of rooms in the underground section have no windows at all.
Besides the obvious problem of escape in the event of a fire, it's just a bizzare experience not knowing which direction you are facing or having no natural light at any time of the day. Something about it doesnt feel right, kind of like the old "Megatron"/McDonalds Resteraunt at Alconbury
My grandad was an architecht and designed and built the place in the early 70's, looks a bit like Austin Powers penthouse....  |
jeds
Joined: 16 Apr 2004 Posts: 2151 Location: United Kingdom Thanked: 265 times
Posted: Mon Jul 20, 2009 4:35 pm |
Putting fire escape regulations aside, all habitable rooms must have purge ventilation. This can only be achieved via a window or, if the room has no external wall, then through an adjoining room that does have a window. In the latter case the opening to the adjoining room must be permanent and is sized based on the floor areas - basically you are talking about a permenant door sized opening here. So you wouldn't have a separate room - you'd have two rooms with an opening between.
Mechanical ventilation is not an option for habitable rooms. |
Shytalkz
Joined: 22 Feb 2008 Posts: 4866 Location: Norfolk, United Kingdom Thanked: 13 times
Posted: Mon Jul 20, 2009 6:36 pm |
Are you Lebanese by any chance? |
