DIYnot
Local | Network
   DIYnot > Forums
Local | Network
low profile shower tray onto floorboards & tanking
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling
Author Message
darren bergin
from United Kingdom
PostPosted: Sat Jul 25, 2009 5:52 pm Reply with quote
im about to fit a low profile stone resin quadrant tray direct onto floorboards..
flooorboard are solid no movement,,,, ive also brought some easybath tanking also
couple questions
whats best to bed shower tray down with ??? i fear sand cement mix would crack up over time
how do i seal using this tanking system do i seal all the floor first ? or do i lay the tray and seal up to the tray with the flexible tape of tanking kit
Do i lay the plastic sheeting over floorboarrds and also seal this to walls
help much apreciated
Back to top
 Alert Moderators
lancenotalot
from United Kingdom
Thanked: 43 times
PostPosted: Sun Jul 26, 2009 1:42 pm Reply with quote
Make where the edges of the tray will come out too then tank from the floor to about a meter up.
Are you going to be tiling the floor?
You can fix the tray to floor using silicone sealant,no need for plastic sheeting.Once the tray is in place seal where it meets the walls.
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Sun Jul 26, 2009 9:33 pm Reply with quote
Wet mortar is best (as is probably indicated in the manufacturer's instructions). As for it cracking over time, has the mortar in the brickwork in your house done so? And, as you say, the floorboards are solid!
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 53 times
PostPosted: Tue Jul 28, 2009 5:30 pm Reply with quote
Personally, I fit shower trays on a 12mm ply board (screwed as per overboarding) to ensure that the load is evenly distributed over all the floorboards under it. Then a bead of silicone and plonk the tray on that.
Not sure about your brickwork analogy dex - surely you're not saying that a brick/brick combination and a shower tray/floorboards combination are even remotely comparable?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling All times are GMT
Page 1 of 1
Jump to:
Bedding low profile stone resin capped shower tray on plinth 3 140 Mon Jan 07, 2013 5:21 pm
Preparing a concrete & floorboards space for Tiling 5 80 Tue Oct 18, 2011 8:01 am
Tiling on wooden floorboards 3 260 Sun Jul 17, 2011 6:25 pm
Tiling on kitchen (Polystenre and interlocking floorboards) 6 240 Wed Jun 29, 2011 5:39 pm
tiling on floorboards. 3 120 Sat Oct 29, 2011 9:33 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
