Lawrence Heasman
Joined: 01 Jan 2005 Posts: 3 Location: United Kingdom Thanked: 0 times
Bahco
Joined: 08 Feb 2004 Posts: 6462 Location: Wolverhampton, United Kingdom Thanked: 5 times
Lawrence Heasman
Posted: Sat Jan 01, 2005 7:51 pm Post Subject: |
Hi
Thanks for the reply, It is black, the external dimmention is 25mm, so I guess the internal bore could be 17mm. Problem is I can see fittings for 20mm pipe 25mm and 32mm but not this size. Fitted (or layed in the 1970s)  |
Bahco
Posted: Sat Jan 01, 2005 8:09 pm Post Subject: |
A strange one this.
If as you say your incoming main is 25 mm you will need to purchase a 25mm x 15mm stoptap and an insert for your plastic pipe.
Fit the 25mm end onto your plastic pipe (with the insert) and a small piece of 15mm copper in the other end. Fit a drain valve and then join up to your existing rising main.
You will turn off the supply at the boundary (recommended)
I am puzzled by the colour of your supply as the black pipe is normally 17mm  __________________ 85 weeks without smoking! |
Lawrence Heasman
