So, I have a problem with my toilet...
Essentially, the cistern has suddenly become extremely slow-filling. I think it's even filling too slowly to put enough pressure on the flush mechanism to close it, so what little water is coming in just dribbles through to the bowl. I'm currently re-filling it with a bucket...
The water is spraying out of the inlet in a tiny jet at quite high pressure, as you can hopefully see in this pic and this pic.
I've done a bit of a search, and I think the inlet valve is one of these. The fittings are definitely made by SIAMP anyway.
I have no idea how this inlet valve is supposed to work, so could it just be blocked up a bit inside? Is water even supposed to be coming out of where it's coming from?
Any ideas/advice much appreciated!
Thanks,
Chris
Thanks,
Chris
