DIYnot
Local | Network
   DIYnot > Forums
Local | Network
High Level Socket wiring & TV Ariel Cable routing
Author Message
bigaljo1
from United Kingdom
PostPosted: Thu Aug 13, 2009 7:36 am Reply with quote
Hello,
Can anyone advise me about the routing of a high level socket for connecting a wall mounted TV? Should I route the cable from the floor as a spur from the downstairs ring circuit or is it permissable to route it down from the upstairs ring circuit? The socket will be nearer the ceiling than the floor. Also is it advisable to route the TV Ariel cable in the same channel as the mains cable. Thanks Bigaljo1
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1015 times
PostPosted: Thu Aug 13, 2009 11:00 am Reply with quote
I presume the TV will be downstairs?
If so, then it would be much better to supply if from the downstairs ring circuit.
You could extend the ring to supply an FCU below the TV at the same height as the existing sockets, and supply the TV from the FCU.
This will allow you to isolate the TV to avoid needing to leave it on standby all the time if you wanted.
The co-ax should be run seperate from the mains to avoid inteference on the TV signal. I would keep them at least 50mm apart it they are run along side each other.
Back to top
 Alert Moderators
bigaljo1
from United Kingdom
PostPosted: Thu Aug 13, 2009 11:25 am Reply with quote
Many thanks for that. I will do as you suggest. Bigaljo1
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
TV reception problem - high winds new digital Ariel required 12 980 Thu Jul 26, 2007 8:07 am
how to repair cut TV ariel cable?? 6 5260 Fri Nov 25, 2005 5:02 pm
How do I connect coaxial cable to a roof ariel? 5 15820 Tue May 23, 2006 9:51 pm
trunking? for ariel/cat5 cables 6 600 Sun Feb 05, 2006 11:19 pm
TV ARIEL MODS 15 3800 Tue Aug 10, 2004 8:46 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
