My garage has its power circuits on a ring from a CU in the garage, protected by a 16A rcd*. I have one particular tool, a planer thicknesser which, when you start it, more often than not trips said rcd. Annoying.
The manual states it is an 1800W device at 240V.
When it doesn't trip the rcd*, it runs fine for extended periods.
1800/240 = 7.5A, by my schoolboy physics, so is there likely to be a tool fault rather then a "power circuit design" fault?
* Edited by moderator - see below - seems to be MCB tripping not RCD
