DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Baxi 105e Boiler central heating not working, hot water fine
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
DrGonzo98
from United Kingdom
PostPosted: Wed Sep 02, 2009 3:15 pm Reply with quote
I'm new to this forum so please bear with me.
I've moved to a new property that has an existing Baxi Combi Instant 105e Boiler. The hot water works fine but when I've tried to fire up the central heating it doesn't work.
When I switch on the CH after 10 second the 'hot water tap symbol' flashes green, the ignition flashes yellow then goes solid. After about 12 seconds the 'hot water tap symbol' goes off and then about 30 seconds later the boiler stops. The radiators at no stage heat up.
I've looked in the fault finding manual and the according to this the 'radiator symbol' should come on green to begin with instead of the tap symbol.
Any suggestions of what the fault might be or anything I can try make it work / diagnose it further?
Back to top
 Alert Moderators
EliteHeat
from United Kingdom
Thanked: 2 times
PostPosted: Wed Sep 02, 2009 4:55 pm Reply with quote
How are you trying to start the heating?
Back to top
 Alert Moderators
Rob
from United Kingdom
Thanked: 391 times
PostPosted: Wed Sep 02, 2009 5:47 pm Reply with quote
The flashing HW symbol is probably pre-heat. Meaning your probably not turning the heating on properly.
Is the timeswitch in the on position? Is the room stat turned up?
Back to top
 Alert Moderators
davebgas
from United Kingdom
Thanked: 254 times
PostPosted: Wed Sep 02, 2009 6:09 pm Reply with quote
Flashing HW light is boiler in pre-heat.
Back to top
 Alert Moderators
gaspro1981
from United Kingdom
Thanked: 257 times
PostPosted: Wed Sep 02, 2009 7:30 pm Reply with quote
Back to top
 Alert Moderators
davebgas
from United Kingdom
Thanked: 254 times
PostPosted: Wed Sep 02, 2009 7:33 pm Reply with quote
Think the OP says it is in opening post mate
Back to top
The following user says thank you to davebgas for this useful post:
gaspro1981 (2 Sep 2009)
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Wed Sep 02, 2009 7:35 pm Reply with quote
Check all external heating controls are on. Check for 240VAC at the switched live terminal on the boiler.
Also check the hw/ch knob has not broken, so will not turn on to ch.
Back to top
 Alert Moderators
gaspro1981
from United Kingdom
Thanked: 257 times
PostPosted: Wed Sep 02, 2009 7:37 pm Reply with quote
Back to top
 Alert Moderators
davebgas
from United Kingdom
Thanked: 254 times
PostPosted: Wed Sep 02, 2009 7:40 pm Reply with quote
Fault finding starts here...... does the CH demand light come on?
Back to top
 Alert Moderators
baxpoti
from United Kingdom
Thanked: 555 times
PostPosted: Wed Sep 02, 2009 8:09 pm Reply with quote
On the boiler incoming terminal block, locate terminals 1 and 2. Isolate , label and disconnect any wiring on here and link the terminals 1 and 2.
Heating now works?
Back to top
 Alert Moderators
davebgas
from United Kingdom
Thanked: 254 times
PostPosted: Wed Sep 02, 2009 8:25 pm Reply with quote
Baxpoti, you're probably the man to ask about a 105e if its ok to PM you?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3487 times
PostPosted: Wed Sep 02, 2009 10:04 pm Reply with quote
If Baxpoti has anything useful to say then he should say it here or in the CC !
Back to top
 Alert Moderators
DrGonzo98
from United Kingdom
PostPosted: Fri Sep 04, 2009 2:19 pm Reply with quote
Elite Heat / Rob 884
I'm starting the heating by moving the switch on the the timer to the 'on continuous position as opposed to timer or off (if that makes any sense).
There is an external control a thermostat on the landing. Some (not all) of the rads also have thermostat valves on them too
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi 105e problem - CH fine, but not hot water 5 480 Fri Apr 18, 2008 6:49 pm
Baxi 105e HW works fine but CH dosn't??? HELP!!! 8 860 Thu Jan 04, 2007 11:53 am
baxi combi 105e ch fine no dhw 5 420 Mon Feb 09, 2009 1:45 pm
hot water working fine but no central heating 3 180 Fri Jan 28, 2011 10:51 pm
Central Heating + showerpump not working, Hot Water Fine 2 40 Tue Jan 08, 2013 1:01 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
