DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Re-siting toilet problem
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
houstonwehaveaproblem
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 07, 2009 6:19 pm Reply with quote
We want to fit a close coupled toilet against a wall but our existing waste outlet will not allow us to do this. The outlet comes up from the floor then bends 90 degrees into the rear of the pan. Due to this we can only have a low level toilet. Is it possible to rectify this??
Cheers
Back to top
 Alert Moderators
Johnmelad502
from United Kingdom
Thanked: 49 times
PostPosted: Mon Sep 07, 2009 6:28 pm Reply with quote
Any chance of a picture with some measurments?
Back to top
 Alert Moderators
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 07, 2009 6:38 pm Reply with quote
Will try. What measurements you after??
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Sep 07, 2009 6:40 pm Reply with quote
build a false wall or use a swan neck pan coupler.
but some measurements would be nice.
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Sep 07, 2009 6:41 pm Reply with quote
how much is the floor waste pipe out by when your new toilet in place ?
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Mon Sep 07, 2009 6:43 pm Reply with quote
A back-to-wall close couple pan set may provide you with the solution - plus you'll not see the wastepipe afterwards.
Back to top
 Alert Moderators
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 07, 2009 6:48 pm Reply with quote
Our toilet is sat quite far forward due to the position of where the waste pipe comes out the floor. Have a look at this pic I just found on the net. Ours is the same waste connection but it comes out the floor a lot further away from the wall
http://media-cdn.tripadvisor.com/media/photo-s/00/14/d0/65/toilet-waste-pipe.jpg
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Sep 07, 2009 6:49 pm Reply with quote
need to know your measurements, how far to much ?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Mon Sep 07, 2009 6:50 pm Reply with quote
Back to top
 Alert Moderators
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 07, 2009 6:53 pm Reply with quote
its a concrete floor and it comes out of the floor about 30 cm from the wall.
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
Mine does too - installed one of these http://www.wickesbathrooms.co.uk/pottery/toilets/blend-cc-toilet-cistern-and-soft-close-seat which cost 250 and not the price on the website. Worked a treat. You may find something similar.
Edit - not 300mm though!!
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1245 times
PostPosted: Mon Sep 07, 2009 6:57 pm Reply with quote
hows he going to fit one of them if the end of the pan connector is 175mm from the wall, and his floor waste is 300mm
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Mon Sep 07, 2009 6:59 pm Reply with quote
Was unaware that is was 300 when I posted it originally, hence the edit.
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Mon Sep 07, 2009 7:00 pm Reply with quote
Back to top
 Alert Moderators
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 07, 2009 7:05 pm Reply with quote
Im guessing my only option really is to build a unit to fit the new cistern against. Ideally wanted it against the wall to give the room a bit more space
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Siting of remote toilet flush cistern 6 280 Tue Oct 05, 2010 1:11 pm
vertical combi boiler flue siting 5 760 Wed Jan 13, 2010 5:32 pm
Gas Meter siting 2 280 Tue Jun 08, 2010 6:34 am
Re-Siting a Filling Loop 5 300 Fri Mar 26, 2010 2:08 pm
Gas Meter Install - Siting Issues. 17 1420 Fri Feb 12, 2010 1:32 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
