Galvanised Tanks - Leave In Situ, Or Remove?
9 Mar 2008
Bath
I have 2 disused galvanised water tanks in my loft from the previous heating system.
Is it best to leave them, or can I remove them? To remove, I would have to cut them up in situ. What is the best cutting tool to use, or is it more hassle than its worth?
Its more hassle than its worth nove them to the side out of the way
Angle grinder in a loft... are you mad :eek:
blanket soaked in bath, hung up n around,grind away
piece of peeish
but it is a hassle,if you need to move em (loft conversion?) use the blanket
if ye don`t, put it to one side
