Hi All,
I'm new to this forum and was searching for an answer to my problem, didn't find one and decided to join so I could ask for advice - apologies in advance as I know I sound like a leech!
I am not in the gas trade or qualified in any related discipline, so this problem is for my own boiler in my own property, I am not using your brains for any profit or taking risks by working like a cowboy on somebody else's boiler.
Right, with all of that out of the way, my problem appears to be relatively simple on the face of it:
All of a sudden at lunchtime yesterday, my wife switched the hot water on and all of the power in the house went off! After this happened a couple of times, it was obvious that the boiler was the culprit - the electricity supply stays on when the boiler is off - when the boiler is switched on again, the main switch on the house circuit board trips and that's that! Because there's no power, there are no fault codes visible on the boiler's display so I can't help you there.
The only other advice I have had is from a friend (who is a plumber NOT a gas fitter!) who has not looked at it who said it might be the motherboard in the boiler - is this possible? As I said there is no power to the boiler so I'm sorry I can't give more info, should I be on the electrician's forum? If it is the motherboard, is this a pro's job? I could change one on a PC but appreciate it's probably not that simple!!
Please help if possible. All help will be appreciated and taken seriously - if somebody says leave it to a pro then that's what I will do, but an idea of the cost of getting a qualified engineer to do the job would be greatly appreciated as I'd rather not be ripped off!!
Thanks in advance
Steve
Thanks in advance
Steve
