Hi there, im new to this forum so sorry if i have posted it in the wrong place.I have a Potterton Prima F boiler which has started making loud clicking (solenoid-type noises).When it switches on normally you get the 'click' then the burner ignites.Sometimes it clicks a number of times.I dont think its the pilot light as I think this is alight.WHAT i have noticed is that if you gently 'tap' the pcb it works again fine for a while.Also when it does this continuous clicking I can see a very small spark (in time with the click) on the underside of the board.I have heard that dry joints are common on these which is what I suspected before I found this out.Is it worth trying to reflow the solder at the sparking joint?(with power off obviously) and also is it straight forward to fit a new pcb (I have some electrical experience)...I was wondering if a new pcb was fitted there may be some other setting that needed to be done which I would be unable to do...........can anyone advise.
Cheers
A
Cheers
A
