DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
RADIAL / SPUR
This topic originated from the How to page called Converting a radial circuit to ring circuits
Click here to return to the page called Converting a radial circuit to ring circuits.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
MCOLLARD
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 12:53 pm    Post Subject:
RADIAL / SPUR
Reply with quote Thanks
HOW CAN I TELL WHETHER A SINGLE CABLE IS A SPUR OR THE END OF THE RADIAL CIRCUIT ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mapj1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 1:57 pm    Post Subject:
Only by knowing where it goes - in a radial circuit there are as many ends as branches. Either measure with a meter, or isolate the circuit in sections.
regards M.
ps please dont SHOUT unless you want to make a special point, its only for EMPHASIS. thankyou.
Back to top
 Alert Moderators
MCOLLARD
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 2:00 pm    Post Subject:
I'm shouting because thought it would be a simple job!! I have a single cable going into a wall and disapearing into thin air and i can't work out where it goes!!
Back to top
 Alert Moderators
MCOLLARD
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 2:03 pm    Post Subject:
I want to move a plug socket up a couple of inches, but the cable is not long enough. Apart from replacing the cable (as i cannot tell where it comes from) how else can i make the cable reach further up?
Back to top
 Alert Moderators
SwindonSpark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 2:34 pm    Post Subject:
Back to top
 Alert Moderators
MCOLLARD
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 2:39 pm    Post Subject:
is it then ok to bury this behind plaster ?
Back to top
 Alert Moderators
SwindonSpark
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 3:09 pm    Post Subject:
Back to top
 Alert Moderators
MCOLLARD
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 24, 2005 3:11 pm    Post Subject:
great thanks for your help....much appreciated. think i might be using this website more in the future !!!!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Jan 25, 2005 5:47 pm    Post Subject:
Surely you know whether the circuit that supplies the socket is a ring or a radial???
Not that knowng that would help you find the other end of the cable....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
MCOLLARD
from United Kingdom
Thanked: 0 times
PostPosted: Tue Jan 25, 2005 5:50 pm    Post Subject:
If i knew do u think i would ask Banal shed!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Jan 25, 2005 6:05 pm    Post Subject:
Thank you for being so polite.
Why don't you find out? It's not difficult to establish.
And while you're at it, explain how knowing whether it is spur off a ring, or a branch of a radial, or the end of a radial, makes any difference to the fact that you can't find where it runs from, and so you can't replace it...
__________________
Back to top
 Alert Moderators
fiz
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 21, 2006 8:59 am    Post Subject:
one way would be to look at the fuses
if there are two cables in
the fuse for the sockets
this may indicate a ring
test continuity of ring
also test the resistance at each socket after
looping the cables
if you have done your 2391 you should
know what reading you should get
if you are unsure
consult an electrician before anything goes
bang
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Feb 21, 2006 10:05 am    Post Subject:
Back to top
 Alert Moderators
fiz
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 22, 2006 8:19 am    Post Subject:
oops
not been on for about a year
i did,nt look at the date.sorry
you might be able to answer a question for me
i am having an extention.
and the kitchen needs wiring
the choice is radial or ring
with it being a kitchen i would have thought
a 4mm2 cable 30amp
after checking diversity
it would be easier to wire a ring in 2.5 but are they not being
phased out in england.
what are your thoughts B.A.S
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Wed Feb 22, 2006 1:41 pm    Post Subject:
Not AFAIK.
My personal opinion is that they are an abberation, and are to be deprecated, so in your position I would install a radial.
If you installed a ring, would the loads be balanced around it?
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Lighting Circuit From fused spur on Radial Mains Circuit? 15 1420 Thu Jul 21, 2005 2:05 am
Spur or radial socket and explanati of 13a current 7 240 Tue Dec 02, 2008 1:09 pm
Adding a spur on a radial circuit? 4 3320 Tue Sep 27, 2005 8:48 pm
Spur off radial fcu 2 260 Mon Feb 18, 2008 11:18 am
Spur from radial circuit?? 6 660 Fri Mar 23, 2007 9:48 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
