Programmable thermostat - two temperature settings
4 Nov 2009
Hampshire
I want to replace an old dial room 'stat with a programmable one. I've just picked one up from Wickes (in the UK) for £55 but on close inspection I think it may have been a bad choice. I don't want to open it up to check the instructions inside as its a sealed pack and I want to be able to take it back if it's no good.
On the outside it says:
"Weekly programming, up to 24 time & 2 temperature settings per day"
I want to be able to set four different temps: medium in the morning, low daytime, high evening and very low nightime.
Does "2 temp settings" mean I can only have two temps, or does it mean I can only have two time periods? I don't understand the "up to 24 time" bit.
without knowing the stat you have bought (what is it)
i imagine you have 24 time settings
and 2 temp settings i.e comfort setting 20-21 degrees
and a setback temp 10-12 degrees
these are obviously not fixed temps and can be changed
Thanks guys for your input. I've just got through to the manufacturer via Wickes (actually quite helpful on the phone - how refreshing) and yes its a One day, 2 temp unit.
[SOLVED]
Get a Honeywell CM907. It provided six temperature settings each day for seven days. You can get them new on Ebay for about £50-55.
Spooky! Have just got back from the plumbing supplies shop with exactly that unit!
Not really, my copper ball is well polished - better than the old fashioned crystal version for answering CH problems! ;) :LOL:
