New bath fitted in my bathroom this afternoon, steel bath (white). Brackets screwed to wall (length side only as front and back ends are to wall/wooden cupbaord as before) and bath secure, bath legs (no middleleg with this bath) fitted OK and 2 planks of wood also used to spread the weight as well (1 unde rback legs and other under front 2)
My query is: the front lip of the bath in the tap corner (side away from wall) has a tiny bit of give in it when you move it up and down, only very slight to the eye.
Is this normal or is there anything I can do to make it better ? Should the feet be screwed to the planks/floor??
Also, will the tiling and bath panel when on stop this slight give??
