Chimney Advice
16 Nov 2009
Surrey
About a year ago, I noticed streaks of moisture, wet to the touch, coming down from where my single flue chimney stack goes through the roof (about 2 tiles down from the apex). A reputable roofing company replaced the flashing (£350), but the problem persisted and got worse. Soot and tar contaminated water was running down the faces of the stack in the loft. The chimney was wrapped in a tarpaulin as an emergency measure and I contacted 4 builders. The consensus was that the damp proof course had failed.
Small damp patches had started to appear on the chimney breast in the bedroom near the ceiling. I decided to stop using the stove for the time being. I also waited for the bedroom stained areas to dry and redecorated after painting the whole chimney breast with Zinsser BIN.
The whole chimney was rebuilt above roof level (£1,700), this time with two damp proof courses and with council building control checking the work.
Needless to say, 7 months later, I am now faced with leaking flashing again and the builder has been called back under the guarantee. At least this time the water is clear. I have a few questions
a) I would like to keep my wood burner, but am loosing the will to persist. I have heard mentioned, that once a chimney starts to leak, its best to have the whole thing removed?
b) I have test drilled the stack where heavily stained and the brick under the rendering appears dry and uncontaminated. Can I assume the the staining is surface only?
c) During heavy rain (before the current leaks appeared) and when the moisture content of the air is high, I have noticed that the stained areas become damp to the touch. Is this normal?
d) I have been told that the stove and chimney would benefit from a chimney liner, back filled with vermiculite. Is this a good idea?
Any advice would be appreciated
Hi. If the DPC has failed (i dont know why it should if made and installed correctly) The only course open to you without spending shed load of money , would be to coat the stack with a translucent sealant, available from builders merchants. However you need a few dry days before applying. If soaks in to the brick work and sets disallowing water to impregnate the brickwork. Good Luck
