DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Peugeot 206 rear axle bearings
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Author Message
Reb
from United Kingdom
PostPosted: Thu Dec 17, 2009 5:01 pm Reply with quote
Hi all
My local garage has advised that I need to replace the rear axle bearings on my peugeot 206, however, they have also advised that it would be easier just to replace the entire back axle instead of just the bearings. Is this correct, does anyone know?
Is it impossible to change the bearings on their own or is the garage just trying to make a christmas bonus on me?
TIA
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2625 times
PostPosted: Thu Dec 17, 2009 6:06 pm Reply with quote
Definitely the way to go is to replace the whole axle / subframe...try a specialist Peugeot breakers ideally for a car thats had a frontal shunt.
Back to top
 Alert Moderators
leewill
from United Kingdom
Thanked: 8 times
PostPosted: Thu Dec 17, 2009 10:22 pm Reply with quote
i`ve worked at a peugoet dealership before and i`ve replaced just the bearings, if you have it done in the dealership it will cost you a arm and a leg in labour costs, and if they are fitting the whole axle with all new parts it will cost you even more, the only reason i would personally replace the whole lot is if i was getting the parts used from a scrappy, but even then i would tend to just replace the bearings as this would be far more cost effective as there isn`t anything wrong with the axle apart from the bearings, but i could do it all myself, and if you can`t then your in a catch 22, probably a days work for a mechanic to replace bearings on a pug
Back to top
 Alert Moderators
Reb
from United Kingdom
PostPosted: Fri Dec 18, 2009 8:16 am Reply with quote
Hi
Thanks for replying and for the info
Back to top
 Alert Moderators
Peter.N.
from United Kingdom
Thanked: 221 times
PostPosted: Fri Dec 18, 2009 7:53 pm Reply with quote
There is a firm near me at Stockland in Devon that supplies completely reconditioned axles for 350 + vat.
They used to fit them as well if required.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
Ldv minibus rear axle 7 1300 Sun Feb 06, 2005 8:02 pm
Pug 206cc Rear axle 8 160 Tue Aug 28, 2012 6:29 am
Ford Focus rear axle snapping 16 1200 Sun Nov 16, 2008 9:15 am
Flat tyre may have damaged axle 5 440 Sun Jan 24, 2010 3:45 pm
torque settings for wheel (axle) nuts 15 9280 Fri Apr 02, 2004 2:51 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
