DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fast Flow Shallow Waste - Bathstore
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Sat Dec 19, 2009 9:23 am Reply with quote
Hi can anyone help with this its got me puzzled
i have fitted this trap
http://www.simpsons-enclosures.co.uk/productsingle.asp?ProductID=684
Installation instructions
http://www.simpsons-enclosures.co.uk/pdf/High%20Flow%20Waste%20Instructions.pdf
purchased it from Bathstore
When the inner filter part (Part with rubber seal) is in place the water doesnt flow once removed the water flows very quickly
What am i doing wrong as it all seems so straight forward
Kev
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 836 times
PostPosted: Sat Dec 19, 2009 4:46 pm Reply with quote
looks very shallow and seems strange to have a "filter" does it go into a soil pipe icon_question.gif IF so and you`ve got the room ...get a HEP V O waste valve with inline adapter from a plumbers merchant and put that in the pipe run leaving out the icon_confused.gif Filter icon_confused.gif icon_wink.gif
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Sat Dec 19, 2009 6:34 pm Reply with quote
Is the cup part fitting correctly in it's intended location ?
If the central tube touches the bottom of the cup it will block the flow. It should stop about a finger's breadth clear of the bottom of the cup.
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Sat Dec 19, 2009 6:58 pm Reply with quote
Yes it stops about 20mm from the bottom of the cup
What if i cut the length of it so it only went 1/2 way down would that make any difference
It seems as thought the water entering the shower waste trap is not pushing the water through.
This is weird as it all seems very simple
Water enters fast flow trap then my waste pipe drop 8 inches then travels along to a tea which is joined with the basin then travels along to main waste/toilet pipe
Why is it not flowing away when the filter is in
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1228 times
PostPosted: Sat Dec 19, 2009 8:15 pm Reply with quote
is your shower 17mm thick where it screws on to the base? the first link you gave shows the shower needs to be this dimension, if its thinner cut the threaded part of the trap.
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Sat Dec 19, 2009 8:32 pm Reply with quote
Not sure ill check the size but surely that wont make any difference, cutting that will just lift the bottom of the trap and exit pipe up closer to the base of the tray.
Will that make a difference
Kev
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1228 times
PostPosted: Sat Dec 19, 2009 8:42 pm Reply with quote
if the shower tray your using is too thin, the threaded part will cover the outlet as you screw it into the bottom bit icon_eek.gif errr if you know what I mean.
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Sat Dec 19, 2009 9:18 pm Reply with quote
Yes i know what you mean but that is not the problem the outlet is 100% clear, it works perfect without the filter, the filter is required really as this will prevent any back smells of waste just like a u bend works in this way.
I think if i were to shorten the length of the filter but still leave it long enough to reach into the cup of water it may work
Ill contact the suppliers on Monday as it seems such a simple install
Kev
Back to top
 Alert Moderators
Ed1
from United Kingdom
PostPosted: Wed Jan 06, 2010 9:27 pm Reply with quote
I have similar issue with the same simpsons shower waste
In my case the water does flow when the waste is put together (admitably only takes the shower at half strength at 7-8lt per minute - but I'm happy with that) the problem behind the soap suds sit on the water surface around the waste will the water flows under them!!
I have contemplated doing exactly the same alteration to increase the flow. It shouldn't affect the water held in the trap to prevent smells as the water height is controlled by the cup. I was also though going to increase the flow at the top of the cup (shown inside the waste in your picture) by cutting a notch out between each of the 8 high parts (difficult to describe!!)
Did you make the alteration? and did it work?
Just wanted to know before I got the saw out!!
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Wed Jan 06, 2010 9:38 pm Reply with quote
Ed i know what you mean regarding cutting notches in i was thinking exactly the same and yes it would still keep the smells out, or you could shorten the part that acts as a seal
Im going to ring the supplier up tomorrow so if you want to hang on ill post here as soon as they give me some advice/remedy.
I havnt made any alterations as of yet
Kev
Back to top
 Alert Moderators
dextrous
from United Kingdom
Thanked: 194 times
PostPosted: Wed Jan 06, 2010 9:40 pm Reply with quote
Are you entirely sure that the cup section is placed as low as possible into the housing? Can't be both of you wrong, surely icon_confused.gif
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Wed Jan 06, 2010 9:48 pm Reply with quote
Absolutely sure - the cup drops in, it definately wont drop in any further, its so bloody easy to set up thats what i cant understand
hopefully ill get the answer tomorrow
Kev
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Fri Jan 08, 2010 2:03 pm Reply with quote
Just spoke to the maufactures and you must make sure there is no air locks in the pipework and the outlet pipe is angled to take the water away.
They are going to send me another waste to try and see if it sorts out the problem
Ill keep you informed once i get it fitted
Ed if you suss it out in the mean time, can you let me know
Kev
Back to top
 Alert Moderators
kevhky
from United Kingdom
Thanked: 3 times
PostPosted: Sat Jan 30, 2010 7:17 am Reply with quote
At last ive sorted the problem, there was not enough angle on pipework running away from the shower it just needed that little extra drop
Works perfect !!!!!!
Kev
Back to top
 Alert Moderators
kaminsky
from United Kingdom
PostPosted: Sun Mar 13, 2011 10:59 am Reply with quote
I have a similar problem to this. I have a very shallow drop from the waste which I can't do much about. Theres a water build up but when i remove the centre part, the waste flows ok. If I just rest the centre part in place rather than pushing it fully in, the water flows ok. I am wondering whether cutting it down a little would help.
Has anyone tried this as the original post suggested ?
Thanks.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Drain Position on a bathstore showertray 2 220 Sun Jun 13, 2010 8:24 pm
bathstore toilet and cistern problem... 4 1120 Sun Mar 22, 2009 12:45 pm
Bathstore.com - Anyone used them? 2 500 Mon Sep 26, 2005 7:37 pm
Trinity Bath Shower Mixer from bathstore 2 220 Mon Jul 19, 2010 8:18 am
Bathstore city space 3 60 Sun Sep 30, 2012 7:50 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
