Jammed key from the filling loop assembly
19 Dec 2009
Lancashire
I struggle to insert/remove the key from the filling loop assembly. It gets stuck and takes alot of patience, pulling and turning to remove it. Could this be damaged and require replacing while I change the diverter valve?
I'm attempting to do all this work myself, I've never done this before.
Can I drain the boiler by closing off the cold water supply, opening a hot tap and opening the pressure relief valve. Would that drain the water in and around the diverter valve etc and that there would be no requirement to drain the radiators.
Your help would be appreciated.
