Positioning intruder PIR's
27 Jan 2005
I want to put some wires in place so that in the future I can wire up an alarm system.
Can somebody tell me what the best position is for PIR's and the places to avoid putting them so as not to get a false alarm.
Cheers.
in the corner preferably near window looking in, so that it is NOT looking at the window.
not above rads, open fires air vents etc
Cheers.
put in most downstairs rooms. i.e passage, kitchen, sitting room etc. as breezer said, not facing a window as it may pick up people outside
err, sorry about this, that is not the reason.
a P.I.R. can not see through a solid object, glass being a solid object.
you position them away from glass as the sun will heat the glass, this the pir will see and cause an activation.
Also to a P.I.R. glass will act as a mirror, enabling it to see some where it shouldn't
:oops: i always thought it could see thru glass
no sorry it can't a microwave detector can though, no problem
Cheers fella's, it shouldn't be a problem locating them downstairs as I live in a bungalow!.
Cheers.
One important thing!.......don't run alarm cable next to mains a/c cable!
Or you will have lots of false alarms.
You would only get false alarms if it was on an ID loop or similar. BUT you should still segregate the two cables to prevent dangerous voltages appearing on the alarm cable due to induction.
not true, most microprocessor panels do not like induced voltages.
to quote Mr jones from dads army "they don't like it up 'em"
Most manuals tell you to seperate the cables accordingly, but to take extra care on ID loops.
Alarms work on low voltage, and full of sensitive CMOS chips, so any a/c induced voltage will trigger the alarm panel. ID chips are programmed individually so they can't trigger the alarm unless it sends it's identity. I was once called to a house the electrician had run the alarm cable with the mains on the first fix, the alarm constantly triggered. We had to power it down and the owner said get rid of it!
