I have a British Gas Boiler 330 located in a garage. The Honeywell 2 channel switch is in twice mode but is currently in "down" period.
The boiler is fired and CH pump is running the weather is cold outside below 2 degrees.
I have a Drayton valve which has H W and Mid positions.
I have tried to run a fan heater in the garage to warm up the boiler but the systems is still running. A friend has advised I should have two separate valves on the replacement boiler system not the one original valve.
Please assist.....
Please assist.....
