heatherw_01
Joined: 21 May 2004 Posts: 133 Location: United Kingdom Thanked: 0 times
Posted: Mon Feb 07, 2005 2:47 pm Post Subject: Filling a large hole in wall |
I have a large hole in an interior wall which is plasterboard. How can I fill this in? |
big-all
Joined: 12 Jul 2004 Posts: 5765 Location: Surrey, United Kingdom Thanked: 24 times
Posted: Mon Feb 07, 2005 3:27 pm Post Subject: |
depends on size and location if its say a 4inch circular hole you can take a bit of wood about 7 or eight inches long narrow enough to fit through the hole[but aS WIDE AS POSSIBLE ] put a screw in the centre just deep enough to grip
cover the overlap area with no nails holding the screw push the wood through the hole and pull towards you till the wood grips the back of the plasterboard
or if its a bigger hole cut the plasterboard back to the stud and the noggins [the horizontal bits]but check there is some noggins by feelling around with something long and thin first before you hack the board off floor to ceiling __________________ big all
we are------------------ all still learning |
TexMex
Joined: 08 Jul 2004 Posts: 1523 Location: Lincolnshire, United Kingdom Thanked: 0 times
Posted: Mon Feb 07, 2005 5:45 pm Post Subject: |
I used the exact technique suggested by big-all recently. I found, however that the "no more nails" stuff kept slipping. In the end i prepared a batton (also about 7" long), predrilled two holes through the batton, then while holding the patch in place (by means of holding the screw in the middle) I screwed the batton to it with some nice long screws. Since the batton is too long to go through the hole, it clamps the patch to the backside of the hole. Next day you simply unscrew the batton, and go for it.
I also happened to have a piece of expanded metal (just hanging about looking for a decent home). So I had sandwiched that between the patch and plasterboard. This made an excelent key for the plaster. |
big-all
Posted: Mon Feb 07, 2005 9:59 pm Post Subject: |
aaaaaaa tex mex pink gripfill has more instant grip skins up quicker [no canabis jokes please  ] __________________ big all
