New Door Lining
23 Jun 2006
Hi there,
I need to install a new door lining to a masonary wall as the old lining is past it. The original lining has been nailed into the masonary using what looks like floorboard nails.
I'm planning to use frame fixings to fix the new one. But how many fixings should be used per jamb? Do I put one fixing right in the centre of the jamb, then go down another foot and put another in etc. Or do I put 2 fixings in side by side, then go down a foot and out another 2 in etc.
I would assume that you use singular fixings so that the door stop will hide the heads of the fixings. But I can see how 2 fixings would allow me to fine-tune the placement of the jamb.
What is the correct method?
i personally put in 2 screws side by side 4 times per jamb.you want put them side by side so you hold both edges of the jamb .drive the screw a couple of mm into the jamb and then fill before decorating.
as chukka says if you only put one in the middle it has a natural tendancy to cup around it. i.e. both unsecured edges warp away from the wall.
ok cheers guys.
Isn't that sometimes a problem when you're only securing to a single skin internal wall and you only have the width of one brick to secure 2 quite chunky frame fixings too? I just forsee each side of the brick coming away when I drill into it...
