Hi all, having to post for advice having tried all i have found on the internet. Background to problem is as follows. The radiators that i have upstairs do not all heat up properly, there is a total of 4 rads, 1 heats up as normal, 1 is probably about 75%, 1 is luke warm and the last 1 is stone cold. Downstairs works absolutely fine and is on 15mm pipework, don't think that this should make a difference!
I have searched all over about balancing, bleeding etc and have tried all the suggestions that i have found. The TRV's all seem to be working ok as i have taken them off to check that the pins are not sticking. Although i was advised that i should change these but have not done this yet! Is it worth it?
All of this has lead me to belive that there is a some blockages in the system. Does anyone have any easy way to unblock this?
It maybe worth noting that i had a new combi boiler fitted last Aug 09, but it seemed ok at the time! Could they have fitted the pipework in the wrong way?
Thanks in advance
Thanks in advance
