DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Problem with an Ideal HE24 isar combi-boiler
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Woodster13
from United Kingdom
PostPosted: Sun Jan 10, 2010 1:50 pm Reply with quote
Hi all, hope you can help.
Please be patient as I have very little knowledge of such plumbing terminology, so I'll try and explain my problem as best I can.
To start with, the heating and the hot water generally seem to be working fine, there have been times when we've set the timer and the heating has not necessarily complied with the times set, and on one occasion stayed on for what seemed most of the day till we turned the timer off from programme.
The problem comes with the pressure gauge. Once we set it to be between 1 and 1.5, it rises when the heating is on, which I believe is what it's supposed to do, but within about four days to a week when the heating isn't on the gauge drops to well below the 1 mark ? To take it back up, now this is very un-technical, we open two valves to rise the pressure, can't be more precise than that unfortunately. That takes the pressure gauge up and we repeat the process at least once a week, is this normal ?
In the last few days we have also encountered some clunking noises (both when heating is on and off), what could these be coming from ? I realise it is difficult for anyone to resolve our problem with this limited information to go off, but any advice would be very much appreciated. Thanks.
Back to top
 Alert Moderators
compheat
from United Kingdom
Thanked: 363 times
PostPosted: Sun Jan 10, 2010 1:58 pm Reply with quote
if your heating is coming on when it shoulld be off that could be the frost stat. the lose of pressure is down to a leak, it doesn't have to be a big leak to lose pressure over 5 days
Back to top
 Alert Moderators
Woodster13
from United Kingdom
PostPosted: Sun Jan 10, 2010 2:03 pm Reply with quote
Thanks Compheat.
If there is a leak, is there anything I can about this myself to check it, or will it be a case of calling out a specialist ? Also, does this need to be done quickly or am I ok to hold on for a while while I build up some piles of cash ?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
ideal isar he24 combi boiler fault 21 16440 Mon Oct 06, 2008 11:29 am
Intermitant Hot Water from Ideal Isar HE24 Combi Boiler 4 380 Wed Jun 30, 2010 7:28 pm
Intermittent hot water problem with Ideal Isar HE24 20 16680 Mon Oct 20, 2008 8:23 pm
Ideal Isar He24 - PCB Problem 9 1700 Sat Sep 26, 2009 8:30 am
Problem with Ideal Isar HE24 4 160 Sat Jan 22, 2011 8:13 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
