DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Shrader Valve - Expansion Vessel
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
MadDesigner
from United Kingdom
PostPosted: Sun Jan 10, 2010 4:47 pm Reply with quote
Hi Forum, not posted on here for years!!! Now back with a question.
I have an Ideal Classic RS Sealed System boiler. It is about 13 years old.
Recently the pressure has been dropping on the gauge. This is due to the air valve on the Expansion vessel being a little leaky. Nothing dramatic but it looses pressure over time and needs constant pumping up. The diaphram seems OK as no water comes out of the valve. No drips from pressure pipe.
I tried to replace the valve insert as per a car or bike tyre but it would not come all the way out. Now the valve is more leaky than ever icon_sad.gif It seems like it should unscrew but not all the way.
Any ideas? It seems a shame to replace a perfectly good expan vessel at 70 for the sake of a part that cost 70 pence.
Thanks In Anticipation
Nick (Mad Designer)
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 886 times
PostPosted: Sun Jan 10, 2010 4:54 pm Reply with quote
get a metal schrader valve cap from a M/cycle shop icon_idea.gif or Halfords icon_redface.gif
Back to top
The following user says thank you to Nige F for this useful post:
MadDesigner (10 Jan 2010)
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sun Jan 10, 2010 4:58 pm Reply with quote
give it a bit more welly..
if it breaks then you're no worse off than you are now in as much as you'll have to change the vessel anyway...
also, could you not get / make up an extension with another shcrader in ito screw onto the valve?
Back to top
The following user says thank you to ColJack for this useful post:
 Alert Moderators
MadDesigner
from United Kingdom
PostPosted: Sun Jan 10, 2010 5:03 pm Reply with quote
Actually - that is not a bad idea. If I can get a bit of threaded tubing (internal and external) and a long threaded nut I have enough space to just extend the exisiting valve. Good thinking.
Any idea what the thread is on these valves?
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Sun Jan 10, 2010 5:11 pm Reply with quote
Back to top
 Alert Moderators
MadDesigner
from United Kingdom
PostPosted: Sun Jan 10, 2010 5:19 pm Reply with quote
Thanks ColJack,
Just the thing! Great stuff. I have a motor factors round the corner I'll try them in the morning. Excellent help. thank you very much
Back to top
 Alert Moderators
MadDesigner
from United Kingdom
PostPosted: Tue Jan 12, 2010 5:14 pm Reply with quote
Just to say I tried all the car motor factors round here and none had any and did not stock them either icon_sad.gif I was about to give up when I remembered that even closer by was a motorcycle shop. They had just the thing as the above ebay link - but even cheaper, with no postage and no waiting. A result icon_biggrin.gif
Nick
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
expansion vessel - where's the car tyre type valve? 6 840 Mon Jan 08, 2007 11:19 am
vaillant turbomax - expansion vessel + valve 2 100 Fri Mar 11, 2011 9:24 pm
Monument Tools - Expansion Vessel pump/valve parts? 8 860 Sun Dec 14, 2008 12:42 pm
Protherm 80E expansion vessel, where is the valve??? 16 1360 Fri May 02, 2008 6:04 pm
SHRAEDER VALVE ON EXPANSION VESSEL 6 120 Fri Nov 29, 2013 9:14 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
