DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Leaking elbow connection on hot water cylinder
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
DJS1
from United Kingdom
PostPosted: Fri Jan 29, 2010 3:48 pm Reply with quote
I replaced my vented hot water cylinder last year because the coil was leaking into it. The elbow connector that joined onto the thread of the prefitted coil was vertical when fully tightened on the old cylinder, but on the new cylinder it's a few degrees past the vertical (nearer the 11 o'clock position rather than 12.00) and over time has worked loose and is leaking(I guess its because the existing pipework pulled it back to vertical). Can I put a felt washer on the joint so that's it's tight when vertical and is there any jointing product I can use in case of weeps?
Thanks in advance for any help.
Back to top
 Alert Moderators
Gasop
from United Kingdom
Thanked: 35 times
PostPosted: Fri Jan 29, 2010 5:49 pm Reply with quote
You will have to remake the joint with PTFE tape or thread sealing string .
You cannot use a sealing washer on the kind of joint you have on your cylinder.
Applied correctly there will be no weeps or leaks.
Back to top
 Alert Moderators
Hugh Jaleak
from United Kingdom
Thanked: 481 times
PostPosted: Fri Jan 29, 2010 6:22 pm Reply with quote
You need to redo the joint as described, and then adjust the pipework to fit. Trying to 'force' pipework to fit is asking for trouble IMO.
I changed a cylinder that had split recently as previous installer had forced return to fit it. The pressure on the primary return tapping has split the cylinder at this point. I cut it off and realigned it to fit correctly.
Back to top
 Alert Moderators
DJS1
from United Kingdom
PostPosted: Fri Jan 29, 2010 8:09 pm Reply with quote
Thanks for your replies.
I made the original joint in PTFE, then tried to remake it bulking it out with further PTFE in order to get the joint tight and vertical - which obviously failed in the end. Am I likely to be able to achieve this with the sealing string or am I just going to have to redo the original pipework? If I have to do some pipe bending I will, but I'd rather not have to right now.
Cheers again
Back to top
 Alert Moderators
lilleville
from United Kingdom
Thanked: 2 times
PostPosted: Fri Jan 29, 2010 10:56 pm Reply with quote
You really need boss white and hemp on cylinder joints, PTFE is too lightweight! You need to re-do the pipework so it sits comfortably. Its no good forcing the pipes, as matey said, you're asking for trouble. Sometimes the only way through it is through it! Sorry!!
Beware not to crack the weld holding the coil in place by forcing it or over tightening it! Got the tee-shirt for that one!!
Back to top
The following user says thank you to lilleville for this useful post:
Nige F (30 Jan 2010)
 Alert Moderators
kirkgas
from United Kingdom
Thanked: 447 times
PostPosted: Fri Jan 29, 2010 11:01 pm Reply with quote
i thought boss white and hemp was banned years ago on all but heating pipes, loctite 55 is the way forward for this type of joint, you can tighten the fitting then back it off if required to line up with fitting, as others have said best to alter pipework rather than strain the cylinder
Back to top
 Alert Moderators
1oldspindle
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jan 30, 2010 12:37 am Reply with quote
Hold it chaps,,,,,,
Why are any of you struggling with these joints at all.
If the correct cylinder unions were being used you would not have a target position to have to re-set in the first place.
Cylinder unions have a tapered fitting on the end that slightly enters the coil tapping then the nut just tightens onto the thread. No jointing compound on the thread at all. icon_wink.gif
Back to top
 Alert Moderators
1oldspindle
from United Kingdom
Thanked: 1 time
PostPosted: Sat Jan 30, 2010 1:44 am Reply with quote
bes.com
Cylinder unions.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 716 times
PostPosted: Sat Jan 30, 2010 9:51 am Reply with quote
Is the coil not a heating pipe icon_wink.gif Locktite, schmocktite icon_rolleyes.gif .If the OP sends me his address, I`ll post him a lock of hemp in an envelope= OR I could start selling it on eBay icon_idea.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Leaking soil pipe vent elbow 9 1340 Sat Dec 22, 2007 4:07 pm
copper pipe elbow leaking, help . 18 880 Wed Apr 15, 2009 4:28 pm
Leaking Elbow Joint 6 780 Mon Jan 22, 2007 4:16 pm
A leaking wall plate elbow? 7 960 Sat Apr 03, 2004 1:50 pm
Leaking Speedfit Elbow 7 3380 Wed May 30, 2007 12:44 pm
DIYnot
